Incoming calls
lvilenskaia
Incoming calls do not go through after installing a new sim card
lvilenskaia
incoming calls/sms do not go through. Restart, update did not help. I tried to put the sim into another phone to test , and that fails to, Please reset network rom the back end
@lvilenskaia
Did you to the text from your old carrier with YES confirming you are porting over to PM? There is a 90 minute window for you to reply.
Contact a CS_Agent to have you old carrier to resend the text if you missed replying.
ORNGNBLK
@lvilenskaia are you a new subscriber? If so it could be an incomplete porting issue. I’ve sent you the number to call them to your private message. If you’re a current subscriber and this is a brand new error only after swapping sims, try to put the sim into another phone to test , and if that fails, send a message to CS_Agent and ask for your network to be reset from the back end. Hope this helps.
