Income Tax
stratford
Need help reaching a moderator with regard to income tax for the year 2024 for 3 family members
7 REPLIES 7
stratford
Hello! I did not! Thanks for the message
did you check the Community inbox?
they usually reply within hours.  Since it has been 7 hours, check inbox first, and write them again if no reply.
stratford
How long does it take for an agent to reply. It’s been almost 7 hours
stratford
It would be great if PM could provide yearly tax receipts but half the year is better than nothing. Thanks again! Hopefully the agents reach out soon as we submitted our business taxes already
slusagm
@stratford CS agent can help with invoices over one year, so, they will help to send you the full 2024 invoices.  But make sure check the invoice dates, when they send me the whole year invoices, the dates were wrong.  Apparently it use the print date instead of the correct invoice date
@Handy1 wrote:
@stratford  You can only go back 3 months I belive but you can ask support if they able to help go back further for invoices
send  a  private message   To CS_Agent
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
As per @Handy1 comment, just know @stratford , CS Agents can only go back one year. So June of 2024 is the cut off.
