In U.S. longer than 10 days - is there a longer add-on plan?
Dawnmi
Hi!
I will be in the U.S. off and on over the next 2 1/2 weeks. I'm wondering if there is a way to do a longer U.S. roaming add-on beyond the 10 days or if I have to renew every 10 days.
Thanks,
Dawn
pakmode
It's a pain OP, so you're probably better off going with a US carrier as others mentioned.
Acekiller
you can give knowroaming or freedompop a look.
koimr1
You'll have to renew unfortunately.
For longer than 10 days I'd suggest using a local SIM or using a WiFi solution if possible.
SD08
Unfortunately, PM doesn't have any roaming add-ons longer than 10 days, so you'll have to renew every 10 days sequentially.  You cannot buy the same roaming add-on again until the previous one expires.  Roaming add-ons also cannot be purchased for a future start date as they always start running immediately.
An alternative is to go with a local provider in the States.
FYI, buying PM's add-ons is a two step process.  The first time you do the purchase process, it simply adds funds to your account from your credit card.  Then you need to go through the purchase process again to actually get the add-on.
