07-17-2020 09:50 AM - edited 01-05-2022 12:08 PM
I was just discussing with another member about life and they commented, "hey make sure to clean up images in your profile, some images that have been sent through private messaging are showing up in your public images."
I am posting this here to let everyone else know that you will need to go through your images and clear out any personal pictures.
@Catherine_T can you please have Public Mobile change images to default into our hidden album rather than our Public album. I had sensitive information that was being displayed in my public album that I had sent to a moderator.
This is a big problem! @computergeek541 had already mentioned this Tiana said it was fixed. Its not.
08-15-2020 06:03 AM
Thanks for bringing this up again i thought it was fixed. It would be nice if this stuff wouldnt get buried.
07-17-2020 01:17 PM
@will13am wrote:
@computergeek541 wrote:Unfortunately, after I said that the issue had not been fixed, I received no further updates. I believe that there is a workaround but I don't recall specifics.
@will13am , do you recall how you were able to send private mesaages and for the pictures to go into the hidden folder?
My private message images have always gone into the hidden folder. I have yet to find a "default" setting anywhere, so I cannot explain the behavior. That said, I have manually moved all my images to the hidden folder. This is pretty easy to do. Just go to my profile, my photos, image options, turn on batch processing, select images to be moved, select move to hidden folder. Because my images are all in the hidden folder, I cannot vouch for whether changes made had any effect or not. Since this manual process is easy, I will continue to be self reliant.
Just to add to this, you need to select a folder to move threads from. You can't do it from all Photos. So select a folder and then you can select all and move.
07-17-2020 12:59 PM
@will13am thanks, turning batch processing on is a godsend. this website just got more advanced lol, it's high tech now!
07-17-2020 10:31 AM
@computergeek541 definitely an issue. I'm sure there is away to fix as I'd assume moderators go back and forth with clients sending screenshots and they don't show.
Fixed whan? Who knows! The quote button still has not been fixed for many mobile devices 🙄
07-17-2020 10:27 AM - edited 07-17-2020 10:28 AM
07-17-2020 10:23 AM
07-17-2020 10:22 AM
You can always do it manually (although for new members they'd likely not know that pics are visible, even a few Oracle's didn't know lol. I only say that as I notified a few of them that personal info is showing on their pictures. Actually even notified Tiana once as a private PM document was showing)
Anyways this how I do it.
Send PM with picture.
Then go to my profile to my pictures.
Open picture I want to hide.
Click image options
Click move image
Select hidden
07-17-2020 10:08 AM
07-17-2020 10:01 AM - edited 07-17-2020 10:01 AM
Tiana was notified of this in June. She responded saying they did some changes to system then @computergeek541 replied saying issue still persist.
07-17-2020 09:54 AM
@Naepalm Oh, did not know that! 😕
Thanks for the heads up.
