IMessage
Mike1099
Does anyone in this community ever have the issue with an e-sim after porting there number over with it saying.
THIS NUNBER IS REGISTERED TO YOUR APPLE ID BUT IS NOT ASSOCIATED WITH THIS PHONE. YOU CAN KEEP USING THE NUMBER FOR IMESSAGES AND FACETIME UNTIL IT EXPIRES.
Thanks
1 REPLY 1
fixin
@Mike1099 Click "Remove" for FaceTime & iMessage, then it will ask to re-add it back onto your iMessage and FaceTime. It should work. Always happens when porting into any provider.
