I will not able to recieve SMS on $20 talk only plan
Neha
I know that I will not be able to send SMS in this plan as its "TALK ONLY". But do I dont recieve SMS as well ? is it ?  I keep on getting SMS from operator  that you need to acitvate SMS service to recieve SMS as well.
@will13am I don't think its a bug; when OP mentions message from operator (Public) I think that is the system generated message being sent about TXT not included in plan
Same way if you try to dial a US number system blocks you and plays a recording
will13am
@Neha, it seems to be a bug with the system spamming customers who have talk only plans.  The easiest solution is to just go the sms app and block the sender.  The messages will stop coming.
kav2001c
No TXT at all on talk only plans
