I want some PUK code
Rosanne1
dust2dust
Do they come in multiple flavours? 🙂
@yackinlyn wrote:
What's puk
@yackinlyn   PUK  = Personal Unblocking Key
could be a sim card unlock key or the carrier unlock key, depends
hairbag1
What makes you think you want some PUK code ? What message are you seeing ?
@Rosanne1
what was the exact error message? Depends on the message, you have to ask the PUK code from different places
If it is a Samsung and if the message is "SIM network PIN blocked. Enter SIM network PUK."
call  Samsung 1-800-726-7864, The only info you will need to provide for a master unlock was the IMEI and where the phone was purchased
If the message is “PIN unlock key (PUK)” or "Enter PUK Your SIM cannot be accessed" or on an iPhone's status bar showing  "Locked SIM"
open a ticket with PM Support using this direct link:  https://urlshortner.tiia.ai/Oyn1L6
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened.  CS Agent will reply you there
If the message is "SIM network unlock PIN" or on an iPhone's About->Carrier Lock showing "SIM locked"
You have to ask the carrier where you got the phone from for the carrier unlock code. (PM would not be able to help with this)
yackinlyn
What's puk
