08-13-2019 03:48 PM - edited 01-05-2022 06:24 AM
I want port my current PC sim in a new phone set and want to keep PC online account active
08-13-2019 04:00 PM
@will13am wrote:@ferdousimam, if you are looking for moderator team assistance with your number port, the moderator team can be reached via private message using this link. Please include a detailed description of the issue and the required resolution. This will speed up problem resolution significantly. Refer to the following knowledge base link for additional information on contacting the moderator team.
Ok it looks like I misunderstood. Do you want to port from PC to PM or would you like to change the phone set? I just assumed PC was a misspell, sorry about that
08-13-2019 03:55 PM
@ferdousimam wrote:I want port my current PC sim
@ferdousimam Does PC refer to President's Choice? When you say port do you mean transfer your number from PC to Public Mobile?
Once you port over a number the PC account will automatically close.
Your message is very cryptic. You need to provide more info so that we can help you.
08-13-2019 03:53 PM
08-13-2019 03:52 PM - edited 08-13-2019 03:54 PM
You can just move it if your new phone is unlocked
If it's locked You can contact the manufacturer of the phone to have it unlocked for free
Which phone is it?
