5 hours ago
- last edited
2 hours ago
computergeek541
I suspect my cell phone has been hacked, as I did not make the call no. 778.580.4001 on the screen show my calling history with unfamiliar call no.
5 hours ago
HI @Anne_Lee
that number is voicemail. You will see that number when you call voicemail to check message or when people left you a message
in fact, the list is bigger, any number found here are all legit PM voicemail number
5 hours ago - last edited 5 hours ago
no hack, no worries
the 778-508-4001 is the voicemail number. the usage will show that number when people called you and got to voicemail or when you check voicemail yourself. It is normal, you are safe
