I still can't use my add ons I purchased on Nov.18
muzmarisa2
I still can't use my 2 add ons I purchased on Nov.18
1 REPLY 1
slusagm
What addon you got? Data add on?  did you reboot the phone?  check if you have a Data limit enabled on the phone, if you do, disable it
and also, try Reset network settings
