I pulled the trigger
erotavlas
Ok I couldn't resist any longer and I submitted my port request from Rogers.  I double checked that I entered all information correctly in the correct order and got this at the end
EDIT: sorry forgot to mention I made sure to follow the advice in the solution to this thread
http://productioncommunity.publicmobile.ca/t5/Discussions/When-will-it-be-safe-to-port-my-number/td-...
I also noticed my Rogers number showing up in my account, rather than the temporary PM number I signed up with.  I hope this is a good sign and that nothing bad happens during the port overnight.
Crossing fingers.
12 REPLIES 12
Mary_M
Retraité / Retired
Retraité / Retired
Welcome to the PM family @erotavlas 🙂
Cheers,
Mary
** Please do not post private info such as: phone number, account number, pin etc.. This is a public forum. **
Rockdaddy22
Welcome to the PM family 🙂
daredogg
Another successful port!  Thanks @erotavlas for bringing us step by step through the process. Robot Very Happy
Nicely done. Welcome to Public Mobile.
ajanda
@erotavlas
Congrats on the switch and enjoy the better value with PM.
You will get a text like the picture above telling you the port is successful.
mimmo
looks like you are good to go:)  failed ports usually allow you to make, but not recieve calls and texts.
glad it went smoothly,
If you can send and receive calls and SMS from your phone, with the ported number, you are good to go.
My port took about 20 minutes to fully complete.  Average is around 2.5 hours for cellular number carrier to carrier.
nishufan
Good Luck.Smiley LOL You already with PM. Welcome to our community.
erotavlas
Just got this text message, Then I tested it by making a call and receiving a call and everything works!!.  Does that mean its already finished?  I thought it takes a few hours or something.  It was so fast. I would say it was only 25 minutes maybe less.
mimmo
Welcome, and let us know, fingers crossed.
ShawnC13
I am sure you are going to be ok keep us updated
stonechucker
@erotavlas, congratulations.
You should get two SMS messages.  One to say your port has started, and a second to complete.
volumes should be low at this time, so I think chances are good for you for a quick port.
My fingers and eyes are crossed for you.
