I only have 49 and won't lete use my card
Babygurlie077
What should I do ?
@Babygurlie077 wrote:
What should I do ?
@Babygurlie077
If your Self Serve is causing you issues with the Payment process try opening a tab in incognito mode, or try a different browser or device.
See allowable credit cards and payment help here:
https://www.publicmobile.ca/en/ns/get-help/articles?q=credit+card
popping
@Babygurlie077
We need more info from you before we can help you?
Do you mean toopup voucher(card)?
Do you mean credit/debit card to setup autopay?
XionBunny
Please clarify what you mean so we can help here, best rule of thumb when asking for help is to be as clear as possible what your issue is, thanks!
@Babygurlie077
Not sure what you meant..
did you you mean:   you have $49 in your Available Fund ?  What is your plan amount?
If that is the case, i assume you have a credit card on the system already.  Did you try to manual pay and try "Other" and enter the amount manually, enter what's outstanding on top of the $49
