I need the puk code
Fern7346
I need the puk code... to use the phone
9 REPLIES 9
liuxinbing
ok. OP may not realized that SIM card and Phone are totally independent each other. The error message on the phone tells which one to be unlocked, SIM or phone. If the phone shows PUK needed, then no doubt it is SIM.
@liuxinbing wrote:
@computergeek541 wrote:
I have merged your messages into a single thread.
You're going to need to know if you need the sim cards's PUK, or if your phone is locked to a different carrier.  What is the exact on-screen message?
If he said specifically PUK, then it is PUK, not the phone.
Sure, but the member also said that he/she needs the phone unlocked. Please see the member's other message.
liuxinbing
@Fern7346 wrote:
I need a code to unlock the phone .. please help
Moderators can only unlock Telus/Koodo devices.  Those don't need to be unlocked to use at Public Mobile.   You will need to contact the carrier that your phone is locked to, or you can pay for unlocking services if you pay some people who sell codes.
liuxinbing
PUK is to unlock the SIM that is locked because of three times incorrect PIN entered. So only the network provider (here the MODs) can provide it. It has nothing to do with the phone.
Triguy
You'll need to reach out for assistance from moderator_team.  Click here to message them
Alex888
@Fern7346 You will need to contact the moderators, you can send them a private message here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Fern7346
