yesterday
- last edited
yesterday
I am switching from Fido to PM. I did request number porting 4 hours ago, and replied YES to Fido’s text message to autorise the transfer.
I however received another text message later on from PM saying they did not receive any reply :
Public Mobile msg: You have requested to move your phone number to Public Mobile. A message was sent earlier to authorize the number transfer. We have not received your response. To reinitiate the request, please reply '1' to this text and a NEW message will be sent to authorize the number transfer. Please call ###-###-#### if you need more help.
I did reply 1 to that message and nothing since then.
Anyone faced the same issue? Does it mean porting failed?
7 hours ago
I think I managed to fix the issue. My phone somehow used PM sim card to reply to Fido's text message. Since it wasn't active yet, Fido never got my YES reply. I reinitiated the porting request again, but this time changed my dual sim cards settings to make sure my reply to Fido would be sent from my original Fido sim card.
Everything seems to be working fine now.
yesterday
I called 1-866-405-8694(Fido port department?) and asked the agent to approve the port-out manually. Hope you can solve it too!
yesterday
Yes! I created a ticket
yesterday - last edited yesterday
Did you read your other post from yesterday?
https://productioncommunity.publicmobile.ca/t5/Get-Support/Number-transfer-from-Fido/td-p/1475142
yesterday
ALERT: As this is the busiest weekend of the year for all mobile providers, it will take longer than usual for porting to complete as well as for PM Customer Service Agent to response support tickets
A critical part to porting is to receive a text from your old provider and you have to reply YES within 90 mins. If you are not receiving calls and text on your PM sim card, and only outgoing calls work, then you might have missed the step and hence porting was not completed
There is a number to call to talk to live support, they can re-trigger the process for you. I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) . Check the envelope icon on top right. Call them and get it fixed
But if you are unable to reach a live support with the phone number I sent you, please open ticket using Public Mobile Expert Messaging , Select Start a Chat to begin (You will need to use your current Community account to login to submit the ticket):
https://expert-messaging.publicmobile.ca/guest/pre-chat
**You'll get email/sms alert when agent replies. or monitor here: https://expert-messaging.publicmobile.ca/message-centre
yesterday
Hi @Anais1339,
Sorry you're stuck waiting. Public Mobile's own transfer help article lists a few things that can hold up a transfer, so it's worth checking them:
1. After you submit the request, your old provider (Fido) sends a verification text. You need to reply YES within 90 minutes.
2. Your old SIM has to stay in your phone, or your old eSIM has to stay active and not deleted, so that text can reach you.
3. Your Fido account and number need to stay active. Don't cancel or suspend them yourself.
4. If Fido has Port Protection or a number transfer lock turned on, it needs to be removed before the transfer.
If all of those look fine and the transfer still hasn't completed, contact Public Mobile support so an agent can look into the request. They can check what happened on your account, which is something we can't do here.
Please don't post your phone number, account number, PIN or IMEI in this thread.
The article is here: https://www.publicmobile.ca/en/get-help/articles/transfer-your-number
Hope you get it sorted soon!
yesterday
- last edited
yesterday
How did you do? I have the same issue. Started the process to transfer my number from Fido last night but still waiting
yesterday
Best to contact a CS_Agent in the morning after 9:00am to look into the porting request so submit a ticket:
Meanwhile, your Fido SIM will continue to work until porting is completed.
