08-04-2023 06:45 PM
08-04-2023 11:15 PM
What phone do you use?
08-04-2023 07:11 PM
You can purchase a SIM if your phone is not compatible with eSIM. They are on sale for $4.99 on Amazon.ca or you can also go to your local Telus/Koodo store for $10.
You should have checked if your phone have eSIM rather than just clicking on eSIM because it is free.
Normally there are no refunds but you can try contacting a CS_Agent by private messaging on the envelope icon on your computer.
08-04-2023 06:57 PM - edited 08-04-2023 06:58 PM
@KasiaSadej what phone do you have? Most eSIM compatible phone is compatible here as long as it has the required network bands
PM is a prepaid provider and does not provide refund . So, you can try to get an physical sim and change to it instead
Get one from:
08-04-2023 06:53 PM
@KasiaSadej Here try this link
private message To CS_Agents click
VVVVV Link below VVVVV
