01-18-2021 12:56 PM - edited 01-05-2022 04:54 PM
I got a new sim card but when I try to change it on self serve I keep getting an error, what should I do?
01-18-2021 01:29 PM
Couple questions I would have, @Pswinks
What is prompting the need to change the SIM card?
How long has it been since you had active service with Public Mobile? (presuming you DON'T have service now)
01-18-2021 01:00 PM
Here is how you can change your SIM:
1. Log into your Self Serve↗ account
2. Go to 'Plans and Add-Ons'
3. Select 'Change Sim Card'
Enter your new 19-digits SIM card number into the field. This number is found on the back of the SIM card packaging
If you suspended your service, you need to resume it.
If you suspended your service due to a lost phone or SIM, here's how to resume service:
01-18-2021 12:57 PM
@Pswinks wrote:I got a new sim card but when I try to change it on self serve I keep getting an error, what should I do?
At what exact point are you getting an error?
