Network issues
Phil222
Why does my Public Mobile app say network is unavailable?
Phil222
My service seems to be working properly now. I did reset my network settings but that did not solve my issues. But for some unknown reason the message has disappeared.
hi @Phil222
you have logged in and confirm your account is active?
To avoid browser cache problem when checking the account status,  please try using Incognito/private/secret mode on your browser to login My Account, or try using the PM app (logoff the app first and log back in)
if it shows active, try Reboot your phone and click Reset network settings and test again.
If same, then submit a ticket with CS Agent using Chatbot here:
             Type the question "Ticket", Then click the following in order: "Account Management" , "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
@Phil222
Check to see if there is any outages in your area:
https://www.telus.com/en/bc/outages
If none then reset the Network setting on your phone and see if that works.
Contact a CS_Agent if that didn’t work:
