06-16-2020 05:06 PM - edited 01-05-2022 11:43 AM
06-16-2020 05:25 PM
Hi I sent you an email..
Anyway, the problem was that in the tab - Add ons it says that its current. But its not true. Its just that I purchased that add on in the past. I just purchased it again and NOW it appears on the " Data & add ons USAGE tab. Now I can see how many minutes I have left.
IT's confusing but got it - thanks
06-16-2020 05:21 PM
@MiguelTonya59 if you are using more than 2 $5 addons Then go up to the $25 plan for the unlimited minutes. Here's an article on switching plans. Choose the renew at next renewal date option. The switch now option loses your balance and immediately charges you for the new plan.
https://www.publicmobile.ca/en/on/get-help/articles/change-your-plan . See below on how to do it.
Welcome to the community. Stay safe.
06-16-2020 05:15 PM
@MiguelTonya59 do you have "available funds" in your account? if you do, you sill have to apply the add-on. it's a 2 step process
06-16-2020 05:11 PM
Are you on the current $15 plan? With free incoming? If not schedule a plan change on next renewal and choose the current $15 plan. Otherwise maybe you should consider changing to the $25 plan with unlimited calling and 1gb of data.
06-16-2020 05:09 PM
@MiguelTonya59 wrote:Hi - for some reason each month I run out of minutes. I added an add on 500 min Canada wide long distance. It still shows in my account in add ons section were you buy them.
current add-ons - 500 min Canadá wide long Distance.
Help!
Are you able to give us a screenshot of your account overview page (with personal info removed) That will help us take a look at things.
