08-18-2020 07:57 PM - edited 01-05-2022 12:35 PM
The address was wrong the correct address is
edited by computergeek541: address removed
08-18-2020 08:33 PM
@shep22 Please remove the address when quoting.
08-18-2020 08:07 PM
I happened to order 2 off of amazon and had little to no issue. If you are having trouble receiving the order and it is off of amazon, you can try and contact the supplier or contact amazon with your updated information. Have a good day!
08-18-2020 08:05 PM - last edited on 08-18-2020 08:32 PM by computergeek541
@Fredjanes wrote:The address was wrong the correct address is xxxxxxxxxxxxxxx
hi you are on public forum please delete your personal info by clicking the 3 dots top right corner to edit your posts
08-18-2020 07:59 PM - edited 08-18-2020 08:03 PM
Hi @Fredjanes ,
Did you purchase them from Public Mobile or another supplier?
If it was Public Mobile you could try contacting the Moderator_Team via private message using this link.
Maybe they have some tracking available for your shipment. Or at least send new ones.
Hopefully, you can get this fixed up!
Also, please edit your post and remove your address by hitting the 3 dots at the top right of your post. This is a public forum.
