01-17-2020 11:18 AM - edited 01-05-2022 09:03 AM
For the Easyfone A4 Prime, I am unable to connect this to the internet, as I need to get the GPS and App Pinnie Talkie to work
Does anyone know how to get instructions on apn edit for the Easyfone A4 Prime?
05-12-2020 02:49 PM
Any chance you changed something else?
I have done everything listed in this thread and still no luck. I can only recieved and send text messages and phone calls.
I have tried with a bell and rogers sim and it works fine. just not Telus/Public mobile. I really don't want to switch providers.
Hopefully someone can help
01-17-2020 03:50 PM
@makkahn28 wrote:Had to Change a wording on the Telus to Mobile Internet, then adding a phrase that was missing, http://aliasredirect.net/proxy/mb/mmsc
The mb was omitted, so had to add that in
http://aliasredirect.net/proxy/mmsc
BUT at least everything is working.
Now if it will keep like this, then I'll be pleased
That setting is for MMS. I don't believe that even needs to be set for data to work correctly and that you just wouldn't be able to send or receive multimedia messages.
01-17-2020 01:55 PM
01-17-2020 01:52 PM
I was able to now have the Data working
BUT it was Painful, and TOO MUCH Trial and Error
At least I know now what to do
01-17-2020 12:38 PM
It is, I checked. Also, an Easyfone specialist claimed that it works as they have Canadian Easyfone users as well. Plus, I can call out and receive Calls and Text
01-17-2020 12:32 PM
The phone may not be compatible with PM. Check frequency specs with manufacturer and compare with PM.
01-17-2020 12:19 PM
I am in contact as well with them
01-17-2020 12:18 PM
@makkahn28 If problem persists, you may want to contact the manufacturer.
01-17-2020 12:18 PM
I also have Add-On Data as well
All the settings look correct. I'm stumped
01-17-2020 12:11 PM
I also checked the Sim and where it is, and that there's ONLY one Sim Slot, and a Micro SD Slot
Plus, the 3G is on
01-17-2020 11:46 AM
These are the settings
Network Account:
Telus
Telus ISP
Clearnet
Koodo
when Clicking Telus,
Name Telus
Username
Passwords
Access Point sp.telus.com
Auth type Pap, Cgap, Pap or Chap, None
IP type Botrh, Ipv4, Ipv6
Gateway 74.49.0.18
Port 80
Set Homepage http://aliasredirect.net/proxy/mmsc
Advanced settings DNS address 0.0.0.0
Network type HTTP
01-17-2020 11:44 AM
@makkahn28 wrote:For the Easyfone A4 Prime, I am unable to connect this to the internet, as I need to get the GPS and App Pinnie Talkie to work
Great phone for seniors.
Closest info I could find, but you may have already read the manual.
https://www.manualslib.com/manual/1633033/Easyfone-Prime-A4.html?page=38#manual
01-17-2020 11:21 AM - edited 01-17-2020 11:23 AM
Take a look at this thread. You may have to switch to 3G Data mode in order for your phone to connect to PM.
