02-06-2025 06:54 PM
I am a new user for about 2 month, I found there is no public point cumulatedin my account, is it normal?
02-06-2025 08:57 PM
02-06-2025 07:03 PM
not normal
did you try checking the My Rewards site using Incognito mode? check again
if still no points, ask PM and they can find out why.
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
Or message them using this link:
02-06-2025 06:58 PM
Hi, If you have been making payments to an active account, you are getting 5% back each month.
Sign in again to the Rewards tab using secret or incognito mode to see how much you have to date.
