3 hours ago
- last edited
3 hours ago
computergeek541
Hello,
I use an apple iPhone 6s. I am unable to activate my public mobile SIM because I could not get the download the public mobile app from the App Store. It seems the version of the OS I run on my phone isn't current enough for the app. is there another way to activate my public mobile SIM
2 hours ago
@amnamohammed wrote:There is no way to download apps if they don’t run on your iOS. Your device is way too old for a lot of apps You can try using PublicMobile on a laptop or computer, maybe set up autopayments?
Good suggestion...BUT...to activate a new PM account, new clients must use the PM app to do so. As suggested, he can activate on a friends cellphone, then friend can delete the app if account is successfully activated.
2 hours ago - last edited 2 hours ago
Your only option since the iPhone 6S is too old to download the PM app. You can have a friend or family to install the PM app on their newer phone and subscribe & activate the SIM.
Once it is activated, power off your iPhone 6S and insert the SIM into your iPhone and you should be good to go. You can manage your account online but remember to have your friend or family to deleted the PM app from their phone.
3 hours ago
@Ketepx , by chance do you know of a friend with a current phone that can install the Public Mobile app and assist with the activation?
3 hours ago
