04-28-2020 02:39 PM - edited 01-05-2022 10:34 AM
Hi,
the first time I changed my number was because the number was not working. The second time I had to do it in hurry adjust chose a random number, now when I go to select aa new number and select it says phone number change failed.
04-28-2020 04:17 PM
@batcamp30 wrote:Hi,
@batcamp30 Once every 30 days, sorry no way around this.
04-28-2020 02:56 PM
@batcamp30 unfortunately, you can only change your number once every 30 day cycle. You can start thinking now about the last 4 digits of the number that you can you would like to get in the next cycle.
Also keep in mind if you have a lot of friends with landlines that its the second set of numbers that determine whether your number is local or not. Ie xxx yyy xxxx. Please check the CNAC website to check if your number is local or not http://www.cnac.ca/co_codes/co_code_status.htm . Personally, I would leave it and dial 1 + 10 digit number and save it in my contacts. If it bothers you, you can change your number to the desired local area code once each 30 day cycle through your self service account.
Stay safe.
04-28-2020 02:41 PM
You can only change your phone# once every 30 days.
04-28-2020 02:41 PM
You can change a number every 30 days in self service.
04-28-2020 02:41 PM
@batcamp30 You can change number once in 30 days.
