07-13-2022 07:54 PM
Activated my Public account yesterday, and ported in my old phone number from my old provider. Data and phone calls and apps have all worked right away, but I'm unable to send or receive any text messages, and I can't locate anything which tells me if I'm checking the right settings.
07-13-2022 09:10 PM
You will need to update the apn in the phone.
https://www.publicmobile.ca/en/on/get-help/articles/set-up-data-on-an-android-phone
07-13-2022 08:11 PM
at the top Get Help
and i Go press straight to Help Articles index,
and there in search type transfer you will found a lot info
07-13-2022 08:11 PM
@malecruzv6 If outgoing and incoming phone calls are working, texting should work too. Did you reply to the text message when you ported in your old number to authenticate the port in request? I wonder if it processed properly or not. Try rebooting your device and send a SMS text to a couple of numbers. Also try sending SMS text to your number to see if you receive anything.
