I cannot submit a ticket for a double charge
mrose
I cannot submit a ticket for a double charge. When it comes to verifying my identity there is always an error and I never get sent a code by sms and I cannot log in. I've sent another ticket regarding this issue and I have yet to hear a response. How do I get in contact with someone so that the double charge is resolved?
2 REPLIES 2
HALIMACS
@mrose
can you tell us a little bit more about what you believe is a double charge?
it could be due to pending versus authorized charges on a payment card, which are being perceived as a double charge, or did you possibly do a plan change before the next regular renewal date?
It’s unlikely you have been charged double unless you have two separate services or accounts created.
@mrose   you can either try to use the 4 digits PIN, if you remember, or you can just direct message to open ticket here
