12-12-2019 12:31 PM - edited 01-05-2022 08:30 AM
Do not enter messages and calls to my cell phone. I can call and my bill is already paid.
12-17-2019 12:36 PM
Check that your sim card is in place properly if that does not cure it you may need new sim card
12-12-2019 03:41 PM
@Francisco_Llano wrote:Do not enter messages and calls to my cell phone. I can call and my bill is already paid.
You can click the "?" in lower right side of the page to talk with moderator and receive assistance. Type 'contact moderator" then follow directions. The moderator may help you with your case. They get back to you in 1-3 hours.
12-12-2019 02:09 PM
@Francisco_Llano Did you port your number in from another carrier? If you did, you will not be able to receive calls until it has successfully been ported. Also, you may experience some issues with receiving short codes via text (e.g. banks, transit) for 2-3 days. Hope this helps, keep us updated!
12-12-2019 01:14 PM
@Francisco_Llano If you ported your number from another provider then that is normal until the port completes. If it's been more than 24 hours then you port might be stuck and you need to submit a ticket to PM so that they can resubmit the port.
12-12-2019 12:32 PM
Try rebooting your phone.
