I cannot find app
YounggeunKang
I tried to download app through qr code to activate my SIM card. But app store told me it was not available in my region. So I changed my region from Korea to Canada in my iPhone setting. However, It still doesn't work
eddieO
@YounggeunKang did you change the region for the App Store setting? You will need to do it here. If you are still having problems downloading the app you can either ask a friend/family who has Canada already set as a region to download on their device and you can complete it that way OR you can contact support to have them do it for you:
You will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
@YounggeunKang  Can you borrow a friends phone to download the app to activate then delete all from there phone and you can manage your account in the website after that
