09-15-2023 08:52 AM
09-15-2023 09:01 AM
@vak1959 are you a current Public Mobile customer?
If so, can you hit the RESEND option a few times and see if an email option appears. Or, enter the incorrect code a few times, and the email option may come up then.
If still nothing, try the "Forgot your email" option and see if that guides you through.
09-15-2023 08:58 AM
09-15-2023 08:55 AM
@vak1959 - can you hit the RESEND option a few times and see if an email option appears. Or, enter the incorrect code a few times, and the email option may come up then.
Are you receiving any SMS, in other words are your services working?
