Tuesday
Tuesday - last edited Tuesday
Click the envelope icon next to your profile. Click the pencil icon and in the "send to" field, type CS_Agent.
This hopefully will connect you to a customer service agent. Response might be delayed so I would suggest sending a message again after around 3-5 days if you get no response. Response will also be delayed if it's after a long weekend.
Tuesday
@cathystrawn wrote:I need to talk to support. but can not submit a ticket
First, please try using the chatbot at
From there, typing in "customer support agent" will immeidatley provide the option to opne a ticket.
If that still doesn't work, please use the following link:
