I bought a subscription with an eSim
Jennchill
The eSim will not work on my  phone to activate my subscription.  How do I get rid of the eSim, as I have a Sim card I purchased for this phone?
HI @Jennchill
yes, usually it is just due to activation issue, not an issue with the eSIM.  Many activating iPhone got the problem and need to change it to physical sim first to complete the activation and then change back to eSIM after
however, nothing wrong with physical sim, especially the fact that it is easy to move around phones.  So, I suggest you keep using physical sim
Jennchill
Moto 5g 2023 and yes I checked and it said yes online but when activating it said cannot use eSim.
Grrrr!
@Jennchill
Did you check to see if your phone is eSIM compatible?
What is the make and model of your phone?
slusagm
PM can help with switching the sim type and enter the sim card number for you.
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket.  So, you will need to message them here:
hi @Jennchill
please ask support agent to update the physical sim card number to your account, you can submit  ticket by direct message:
