05-14-2019 08:29 AM - edited 01-05-2022 07:29 AM
05-23-2019 11:16 AM
Where did you find the instructions on "Resetting your network"?
05-23-2019 10:23 AM
Are you in a new area or have you had better service in the same area with PM?
05-23-2019 06:53 AM
I reset network settings, as recommended, and so far all is good, Thank you.
05-14-2019 08:31 AM - edited 05-14-2019 08:32 AM
@Darlene_turpin6, there was a widespread dropped call issue affecting a number of customers. The problem was reported as resolved (see link below). If you are still experiencing this problem, you need to contact the moderator team for resolution. The moderator team can be reached via private message using this link. Please include a detailed description of the issue and the required resolution. This will speed up problem resolution significantly. Refer to the following knowledge base link for additional information on contacting the moderator team.
