I activated my SIM card and now don't know what to do with my android phone
blairq
@hartandhome wrote:
There is a spot on the phone to put the new SIM card in. I will attach a link to a video that might help.
https://www.youtube.com/watch?v=3XVazimL47I
That's kind of making a broad assumption that the OP is using a phone with that sort of SIM tray....
hartandhome
geopublic
@blairq  Remove the old sim card and insert Public's sim card and enjoy your service. Therr usually is a pin hole on the side of your phone insert a pin or the sim tray ejection tool that came with your phone to get access to the sim tray
Dunkgirl
@blairq  What do you mean you don't know what to do with your andriod phone? Did you insert the sim card to the phone yet? What is the problem, what do you need help with? You have a title but your post is empty.
popping
@blairq
I am using an Android 9 phone with PM.
Which Android phone do you have?
