03-17-2019 10:13 AM - edited 01-05-2022 03:46 AM
Hello,
Yesterday I activated 3 PM SIM cards and ported the numbers from a Rogers share everything plan.
Two of the three numbers have ported and all seems well with them. The third number (ironically the first one I set up) seems to be only partly moved. The account is set up in PM, PM is indicated on the phone, texts seem to work. The phone number still shows on the Rogers account and voice calls to the number go directly to the old Rogers voicemail.
From looking around the community I suspect that this is a hung port.
My question is this - can I contact the moderators directly or do I need someone to “tag” a mod?
Thanks
Joining Public
03-17-2019 10:30 AM
@Cw36 you also might be receiving a call from the telus porting team, on the alternate number you provided. so have your rogers information handy(account number and account name). this happened to me a couple weeks ago wheni had an incomplete port.
03-17-2019 10:21 AM
Thanks for the quick responses - I will contact the moderators!
the community is sooo much faster than old school customer service “priority sequence”
03-17-2019 10:18 AM
03-17-2019 10:18 AM
Hi @Cw36 ,
Welcome to PM. From experience, that sound like porting process/delays and it usually resolve by itself less than 24hrs sometimes. Meanwhile you may also need to privately contact the moderators with your number if you've aleady chosen one together with the 4 digit number you attempted to sign up with.
03-17-2019 10:17 AM
Contact the moderator by clicking the following web address: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
Be sure that you have the Rogers account number available.
