How to view Transaction History beyond 6 months/180 days?
DangitBobby
Is there any way to view your Public Mobile Transaction History on Self Serve beyond the 180 day rolling period? Need my older transactions for tax reporting.
darlicious
@DangitBobby
Here is a thread and an example on how to request an invoice from pm for tax purposes.
https://productioncommunity.publicmobile.ca/t5/Get-Support/Request-a-Receipt-for-your-Account-Charge...
JL9
I am assuming if you have to go beyond 12 months you should still be able to through the above method depending on how far back you are going for tax purposes.
@0077 wrote:
@DangitBobby
Send a private message to the CS_Agent, and request an invoice for 12 month. here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
*Monitor your Community inbox, envelope on the top right, after ticket is opened. CS_Agent will reply and work with you via message*
Encouraging a member to go through the private messaging route automatically results in the customer receiving slower service.  Whenenver possible, the ticketing process that is in placed should be used.
Sorry, but you can't see that information in your Self Serve account.  You can ask for a receipt by asking a customer support agent. The proper way to do that is to do that through:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html
JL9
I am assuming if you have to go beyond 12 months you should still be able to through the above method.
