How to upgrade plan
Naysir08
How do I upgrade my plan?
@Naysir08 wrote:
There are no plans that are listed that is the upgrade to what I have. …I was wanting the $40.00 plan but it is not listed?????
Sorry, but the $40 plan is only available to new customers.
Naysir08
Hi @Naysir08
you can make change to plan by going into My Account, click Change Subscription. Then pick the plan, select either Change Now or Change on Renewal.   Buy better to use Change on Renewal
dust2dust
Log in to your account, subscriptions & add-ons, change subscription, select a plan, preferably choose for next renewal, finish.
