2G On PM
thecynic
Hi,
Does Public Mobile support 2G (GSM) devices? Will that technology be supported for a long time in the future?
Thank you.
2 REPLIES 2
DennyCrane
Telus and Bell never had a 2G GSM network. Prior to the 3G HSPA launch they both had CDMA networks. Public Mobile uses the Telus network, so no, no 2G.
dust2dust
No. The only provider still holding on to it is Rogers and that is being phased out. You can however you use it for roaming on T-Mobile in the states with the roaming add-ons or plans from here.
