03-05-2026
09:43 AM
03-06-2026
09:54 PM
computergeek541
Considering on switching from my hard sim to e-sim. Do I need to purchase a new e-sim or do I just do it on my phone for free?
03-06-2026 09:59 PM
@slusagm wrote:Public Mobile does not support convert to eSIM frature
"No, converting a physical SIM to an eSIM on an iPhone does not work for all carriers. While the technology is supported on iPhone XS and newer models, the ability to perform this conversion directly on your phone depends on whether your specific wireless provider supports that feature. "
In this case, the customer doesn't have an eSIM.
03-06-2026 09:56 PM
@Anerkons wrote:Are you sure I have to pay for an e-sim. I ask because on my phone there is the option to change to e-sim but I don’t want to experiment just now.
htidegnow has provided you with the correct information.
03-06-2026 06:42 PM
03-06-2026 06:36 PM
03-06-2026
12:19 PM
07-03-2026
02:09 PM
@Anerkons wrote:Considering on switching from my hard sim to e-sim. Do I need to purchase a new e-sim or do I just do it on my phone for free?
hi @Anerkons
changing from Physical to esim is not free, it is $5
if you are ready to change, download the PM app on the new phone, login to the app, go to Account page and choose Buy sim card and select eSIM.
