How to see how much data i have left?
bulia
i have the 3 month plan for 12 gigs
where can i see how much data ive used and how much i have a left on a MONTHLY basis?
the "usage" window is arcane and useless, where is the aggregated view?
37 REPLIES 37
Can you go to Plan and Addons and then Addon Usage it might show there.
bulia
bulia
it says that i don't have any add-ons......
@bulia  when you log in on your overview tab if you scroll down to addons you will then see what you have used of your data
bulia
when i sign on, the first page i see is the "overview" page, there is nowhere to scroll down to and i don't see any mention of data usage
there's a link to "view my usage" but it only shows about 15 entries at a time and no aggregate value
ShawnC13
@bulia  have you logged into your self serve and checked there.  You will not see a MONTHLY remaining as it is 12 GB for 90 days.  On your first day of a new cycle you would have 12gb available for that month, next month anything left you would have whatever you didn't use available for that month.  If you use it up you are out of data and would need to buy more or wait for your new cycle to start.
stonechucker
When you sign in to self-service, the first page you see, you can scroll down and see for the 90-day period, how much you have used.
Simple subtraction will give you your remaining data availabe for the 90 day period.
There is no display of the "monthly" average data available.  Your data is for your entire 90-day period.
