Account set up
Keithneeds
I started to order a plan .i entered all my credit card info. How do i remove that card data and cancel
Keithneeds
I am slow to reply but thank you for your reply. It was the help I needed to set me in the right direction
@Keithneeds   The direct/private message system @hTideGnow  gave you a link to is not A1, it puts you in contact with a Public Mobile customer support agent.
Keithneeds
Thank you for your live help. I need to cancel because I can not manage thru this system of robotic communications.
HI @Keithneeds
you want to cancel already?
You will have to ask support to help , you can submit  ticket by direct message:
