a week ago
Hi there, would someone be kind enough to help me with this ? I searched "How to redeem points to lower my bill" in the community but nobody really answered that question.
When i login to my account, i get a pop-up window that says click on "My rewards". I clicked but it gives me a blank page with Public mobile on top. I checked in the menu options but there are no options for the rewards. Can someone tell me how to do it or where to find it please🙂?
Thanks
a week ago
That's how you can reach the redeem page in the PM app.
a week ago
I agree! Thank you very much for your help and guidance, fast, clear and simple. I really appreciate. Problem solved😀. I will accept as a solution !
a week ago
Yes @Serenit
One of the biggest disappointments (and one we're REALLY hoping they'll change), is having to wait to get to 15 points before being able to convert to $15
They really need to change that and should make it 5 points minimum towards $5
a week ago
Clearing cache solved the problem. I see that i have only 9.25 points. If i want to apply my points to get a rebate on my next bill, i have to click on catalog? I clicked but there is nothing there... someone wrote that i have to wait to get 15 points at least. So when i get 15 points, "catalog " is where i have to click to apply a rebate?
a week ago
Ok, lol i only have 9.25 points so when i click on catalog there is no offers. So i guess i have to wait to get at least 15 points? thanks!
a week ago
What I tend to do, @Serenit , is switch from a web-based login to My Account to the Public Mobile app if one method doesn't seem to give me the options I need.
I almost always get the function I need to do when relying on one or the other methods.
a week ago
Website is finicky with caching issues. Try to login by first clearing cache, incognito mode or a different web browser.
Click on the Rewards on the left side of page and then click on Visit rewards.
Then a new webpage should load up with your Rewards page. It should show how many points, etc.
a week ago
@Serenit , when in the rewards portal, you need to use the catalog to select the option to convert 15 points for $15.
a week ago
@Serenit Yes, I get a pop-up window also with a blank screen. I'm hoping this will be corrected soon .
But if click the x at the top right on corner it will lead you into the account where you can then click to My Rewards.
You will see the catalog you can search by all. There is one there for 15 points for $15.00 bill credit.
