04-27-2020 06:02 PM - edited 01-05-2022 11:47 AM
If I port my number from PM to another provider, how can I still keep my PM SIM card active (with any random number)?
04-30-2020 01:07 AM
@computergeek541 wrote:
@Anonymous wrote:
@computergeek541 wrote:What everyone said.
How many will I be rewarded with?
Comedy gold. You'll be here all week right?
You know that I've been around. Truth be told, the actual amount of activity is very much decreased in Community of late. If there's nothing to add to a thread, I generally try not to post for no reason. My post was meant as a slight nudge about repetition.
I knew immediately that it was a nudge. I know you're around. That was a reference to a stereotypical line a comedian might make saying that he'll be here all week performing...comedy.
04-30-2020 01:02 AM - edited 04-30-2020 01:03 AM
04-30-2020 12:36 AM
@Anonymous, am tempted to bravo you but, it's against my principles.....brahhhaaa
04-30-2020 12:29 AM
04-29-2020 06:05 PM
What everyone said.
04-29-2020 09:37 AM
No, you will have to buy another PM sim card and activate that with a new 'random' number
04-29-2020 07:15 AM
@sahands, before you throw away the Public Mobile Sim card, make sure you remove all the information on the card!
The card holds your personal information and you should completely destroy the card to prevent theft.
04-29-2020 07:06 AM
@Pawprints1986reuse it.You can put a hole through it and make a SIM card necklace.
04-29-2020 06:07 AM
@sahands that really is a waste ! I kept my old koodo Sim figuring if I need a device at some point I'll have to move back over. It is a waste though, if you can still read the number on it fully and the card itself isn't damaged in any way it seems a shame to just throw it away... I'm not a fan of wasting anything though. Reactivating an old Sim would be the perfect way to recycle, sucks you can't 😕
04-28-2020 08:33 PM
well confirmed it with a mod, the old SIM card becomes garbage afterwards and can never be reused! such a waste 😤
04-28-2020 04:12 PM
The company closes the account after number is ported! So this can’t be done
04-28-2020 02:47 PM - edited 04-28-2020 02:47 PM
@Luddite wrote:
@BearFBI wrote:@sahands No you cant. You will have to buy a new SIM. There only 10$. I would suggest contacting a moderator after you port out and close the account if you can use the same email again. You can buy it from this website. There half price https://canadiancellsupplies.com/
👎👎 This seems a total waste of moderator time simply to avoid using/getting a different email address.
@Luddite True. but ive seen other peoples accounts on the forum get canaled after 90 days of inactivity and they got a new SIM and number and contacted the Mods for them to apply their old email. But it would be much easier to just use another one. I wouldn't say its better because having 1 email for everything is easier than 2.
04-28-2020 02:43 PM
04-28-2020 02:31 PM
04-28-2020 02:30 PM - edited 04-28-2020 02:39 PM
@sahands wrote:@shaker Are you sure I'll still be able to reactivate my old SIM with a new #? I know that with other providers like Rogers the old SIM can never be reactivated again.
@sahands No you will not be able to reuse your old PM SIM once you've ported out. You would need a new SIM and a different email to the one you've used.
04-28-2020 02:27 PM
04-27-2020 06:54 PM
After porting your existing number your current PM account will get closed.
Then, you can open a new PM account & activate your PM SIM card with a new number.
04-27-2020 06:31 PM
Port out you number to another provider means you are closing your account with your current provider.
This is the definition for all mobile providers in Canada. PM is no exception.
Since PM is a prepaid provider, therefore, any fund left in your account will be gone too because there is no refund of the money left in your account. This is also a standard practice for prepaid account in Canada.
04-27-2020 06:08 PM
04-27-2020 06:04 PM - edited 04-27-2020 06:05 PM
@sahands Hello once you port your number from p.m. your account closes sorry you can’t keep it open
