How to activate the data sharing
Edrick
When i want to do a data sharing it says that public mobile have to activate it
7 REPLIES 7
@rceccato- Unfortunately, @Edrick never got back to us to update. Check the APN settings in the phone.
settings, mobile data, mobile data network, fill in all the settings - let us know if you're unclear on them.
Also - settings, personal hotspot, allow others to join, turn on wifi and bluetooth, set a wifi password.
rceccato
Are you sure about this.  I have an iPhone 14 and I keep getting the same error about Public needs to turn it on.  I am on the 40.00 16 GB plan.  Any ideas??
HI @Edrick   If it is about hotspot, did you try it and it  failed?
Check your APN, some needs this for APN type :
default,supl,mms,dun
LeePublic
Do you mean hotspot data or sharing your data plan with other people in your family?
There's a lot of tutorials on how to enable hotspot on your phone by Googling the question.
You can't have a family plan on Public to share your data with others. One account per plan.
Yummy
How do you define 'data sharing'? PM does not offer that.
If you think of 'hot spot' it depends on your phone.
@Edrick  - you can share your data by hotspotting it, if you wish. edit as @computergeek541 pointed out as well.
See how to do that here:
https://www.pcmag.com/how-to/how-to-turn-your-phone-into-a-wi-fi-hotspot
There isn't anything for Public Mobile to activate.  Hotspot is fully enabled at Public Mobile. This is a device software issue.  Which model of phone do you have?
