How to activate a sim card
Jim1502
I have a new sim card for a new phone.
How do I activate it?
@Jim1502   if you are an existing subscriber and just changing phone and changing sim card, you DO NOT try to activate the new sim card
instead , you can first try to move your sim card form your old phone to the new one, it should fit
@Jim1502
Download the PM app and click on Shop Subscription Plan then follow the prompts.
abtest
@Jim1502  - If it is for a new phone (that is not already using PM), then you will need to sign up from scratch.  If you already have an account & number from PM, you can simply change the SIM associated with your account>
