11-13-2020 06:40 AM - edited 01-05-2022 05:26 PM
•What’s the easiest way to change your voicemail PIN? (iPhone user).
•Would changing VM PIN delete current VM greeting?
I tried calling my voicemail to do it but could not figure it out. I also tried doing it in self serve but got an error message.
11-13-2020 06:57 AM
@trgtrg2020 correct. Only mods can do the account pin.
If you need to change it you can open a ticket for them through the chat bot
Or send them a private message at link below.
11-13-2020 06:56 AM
There isn't a way to change your account pin except to ask the moderators.
11-13-2020 06:55 AM
@cellphoneuser1 Only MODs can change Account PIN? I wish they allowed us to change ourselves lol.
11-13-2020 06:52 AM
11-13-2020 06:50 AM
@Jb456 I tried it and worked perfectly! Thanks for the help.
11-13-2020 06:45 AM - edited 11-13-2020 06:47 AM
@trgtrg2020 You have to hold the 1 key down and change it in the options. If you forgot.it, go to the self serve account to reset the voicemail password.
@esjliv Voicemail PIN and account PIN are seperate. Mods don't change vociemail PIN.
11-13-2020 06:45 AM
@esjliv incorrect.
@trgtrg2020 call your voicemail.
Press 4
Press 4 again
Press 1 to change voicemail password.
No it will not affect your greeting.
11-13-2020 06:42 AM - edited 11-13-2020 04:11 PM
@trgtrg2020 wrote:•What’s the easiest way to change your voicemail PIN? (iPhone user).
Hello @trgtrg2020 ,
thanks, thinking account PIN! -
disregard 😕
