09-09-2025 03:45 PM
09-09-2025 05:01 PM
If you just ported your number from another carrier. Don’t reply to the text from your old carrier confirming you are porting over to PM.
09-09-2025 03:49 PM
Click on the envelope in the bottom right corner and follow the prompts and you can get help
09-09-2025 03:48 PM
hi @Lucas2006
if you want to cancel a number transfer, you still need to pick a new number
Simply login My Acount, go to Profile and click Pencil besides the phone number and get choose a new phone number
if you cannot login, then ask PM support agent to help. You can submit ticket by direct message:
