How do I view usage history past 90 days?
04-04-2020 03:39 PM - edited 01-05-2022 10:14 AM
Hi all,
I'm trying to look up my usage history for December, but I'm only allowed to go back 90 days, which is January 4. Does the system delete usage history beyond 90 days? If not, how can I recover it?
Thanks.
Joining Public
04-05-2020 12:46 PM
You need to sign up in “ my account “ online and you’ll be able to see all your personal info and the usage of your account.
04-05-2020 01:01 AM
Hi, please contact a moderator, they will be able to assist you with that.
04-04-2020 04:37 PM - edited 04-04-2020 04:39 PM
You are right @popping my bad. 👍 Sorry @dh1984 steered you wrong on this one. Moderator help is required as mentioned above.
Check your private message sent box (click on the envelope top right of your screen) to make sure the message was sent. Also keep an eye on the envelope, the mods answer will show up there.
You can also enable email notification to receive a private message notification sent to your email.
Go into your community account > my settings > PREFERENCES > Private Messenger > enable "Receive email notifications for new private messages" > Save
04-04-2020 04:36 PM
OP is asking for usage history. Not payment history.
04-04-2020 04:32 PM - edited 04-04-2020 04:40 PM
04-04-2020 04:01 PM
Ok will do. Thanks.
04-04-2020 04:00 PM
04-04-2020 03:58 PM
Can I respond to my open ticket?
04-04-2020 03:54 PM
@dh1984 wrote:I just submitted a ticket. Thank you.
Please ask moderator to create an internal tech support ticket to fix the interface to allow us to search at least 1 year.
04-04-2020 03:52 PM
Looking for my call history.
04-04-2020 03:50 PM - edited 04-04-2020 03:52 PM
@dh1984 What type of usage are you looking for?. Depending on your device you can review call logs (via Google settings) and data usage back to December.
04-04-2020 03:50 PM
04-04-2020 03:48 PM
@dh1984 wrote:Hi all,
Thanks.
We cannot go back to 2019 using the start and end date search.
04-04-2020 03:46 PM
You could submit a ticket to a moderator by clicking on the question mark on the bottom right.
04-04-2020 03:45 PM
@dh1984 hi you will need a moderator for that click on the ? bottom right
04-04-2020 03:45 PM - edited 04-04-2020 04:41 PM
