3 weeks ago
- last edited
3 weeks ago
computergeek541
3 weeks ago
Thanks for this explanation. It does suck though.
3 weeks ago
Yeah , my bill went up also. This REALLY SUCKS!
3 weeks ago - last edited 3 weeks ago
$84 I Suggest you look at the new plans there got to be something cheaper than that. Like the 34$ 50g can/us plan and save some money or the $50 100gig. Just make sure you change on renewal.
Just noticed that the 84 was a total for the year. But it still won't hurt to check out the newer plans
@froglike , we are all in the same boat here. It's rough, man!!
How much points for you have? You need a minimum of 15 for a $15.00 bill credit.
Add-ons start at 5 points.
If you have enough, sign into your account, click My Rewards. Browse the catalog and choose the bill credit redeem button.
https://myrewards.publicmobile.ca/
While you are there, shop subscription to see if there is a cheaper plan you might be interested in. If so, click Change on Renewal so that you are not charged immediately for the new plan without finishing the current one.
