05-19-2025
08:51 PM
05-19-2025
08:58 PM
computergeek541
05-19-2025 08:55 PM
all you need to do is to buy first , pay $5 first and ask them to give you back the credit. Everyone does it that way
05-19-2025 08:54 PM
hi @Taha2
esim cannot be transferred, but you can buy a replacement for free
What you need to do is to download the PM app on the new phone, login to the app, go to Account page and choose Buy sim card and select eSIM.
the system might still charge you the $5. Pay and install the esim first.
After the new esim is installed, submit a ticket with PM agent and for reimbursement. You can submit ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
05-19-2025 08:54 PM
@Taha2 Sorry you can’t transfer eSIM , instead log into the app with new phone and rebuy esim on new phone . The system should recognize you already paid for eSIM and credit your the money back at check out and if it dosent just message support and they will credit it you back . And you will keep same phone number and plan
r send a private message To CS_Agent
