05-30-2022 06:03 PM
05-30-2022 06:16 PM
HI @Jackalwest
hope this helps:
at : https://publicmobile.ca/chatbot. Follow this to get to ticket open screen quicker:
And you can also share your problem, we can try to help
05-30-2022 06:13 PM
To contact CSA-agent, there are 2 methods:
If ticketing does not work very first time, contact agent directly.
05-30-2022 06:06 PM - edited 05-30-2022 06:07 PM
@Jackalwest you can start one here https://widget.telus.tiia.ai/publicmobile/publicmobile.html
05-30-2022 06:05 PM
Go to the bottom of this page and click on SIMon Chatbot or private message a CS_Agent on the envelope icon on top of this Community page.
