11-29-2023 09:33 AM
I have a new plan with Rogers and would like to move my current phone number to that plan. Rogers has asked me for my account number, which I can't seem to find.
Can someone please tell me how to do this so I don't lose my phone number?
11-29-2023 09:43 AM
@Paul8330 wrote:I found it. Thank you
Do you need note my account that I'm porting the number to Rogers? And is there anything else you need from me to ensure this is done correctly?
You don't have to advise PM that you are porting out, they will get that notification when it happens. Just make sure you keep your sim card in your phone to confirm the port.
11-29-2023 09:41 AM
11-29-2023 09:39 AM
When you log in to your public mobile account, click on my account. You'll see your profile under there. You should see your account number. That is what you need to start the process.
Ensure not to remove or destroy the physical Sim if that's what you have.
11-29-2023 09:38 AM
To port out, you start the process from your new provider
But first, make sure your PM account is currently active and you can receive text without problem. Login to My Account and get the account number from Profile page https://myaccount.publicmobile.ca/en/account/my-profile
While you are at My account, you might want to also disable Pre-Authorized payment just in case.
Go to Payment page, click Manage Subscription, then turn "Subscribed" to off
https://myaccount.publicmobile.ca/en/account/my-payment/manage-subscription
Now on the portal of yoour new provider and request to port a number. Provide them PM's account number as the porting information
this is critical: Then still have your PM sim card in the phone, wait for PM to send you a text to confirm your porting request. You need to reply YES within 90 mins
After you replied yes, you can put your new sim card in the phone and wait until you get incoming calls. Once you are getting incoming calls, porting is completed. Your PM account will also be closed at this stage (you will no longer be able to login to PM My Account after)
11-29-2023 09:36 AM
Log into My Account and then select "profile". you will see your account number there.
